Salta al contenuto principale
Con gli auricolari Bose Sport Earbuds la musica sembra così vicina da farti sentire l'artista proprio accanto a te, spingendoti a fare un chilometro in più o un'altra ripetizione. Il design brevettato delle porte acustiche e i driver premium ad alte prestazioni si uniscono per offrire un suono eccezionale in un piccolo pacchetto acustico.
Power problems and unable to update
My earbuds got 3 flashing lights on the case and after using the Bose updater on PC they are not recognized by the case and the case thinks the earbuds are out of the case. Therefore I can not update them. Tried to reset the case using the Bluetooth button but the earbuds flash only once. When opening the case both the lights on the case and the lights on the earbuds do not work. When charging the lights out of the five on the case flash(1st, 3rd, 5th,). After a while only the first light starts flashing as if the case is charging but after a few hours only the first light is on. When unplugging and then replunging the case to the power source the same cycle happens 3 lights flash and after some time only the first light flashes(as if the case is charging). Any ides on what is this problem about will be well appreciated!
Thank you in advance!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
The batteries are dead and you need to replace them. I was hoping somebody haf managed to do the replacement so i could get started.
Punteggio 0
Aggiungi la tua risposta
Philippe Ainouz (Phosmo) sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 51
Tutti i Tempi: 1,175
