Salta al contenuto principale
Nintendo Game Boy Advance, uscito nel 2001. La riparazione richiede solo strumenti comuni e nessun calore.
Very dark screen when playing games
I’ve just purchased a second hand game boy advance and it’s quite hard to see the game due to dark screen. I’ve tried the usual holding select and clicking left/right but no good. Also found the pot behind the serial number but no good unless I need a very small screwdriver but not sure. Any help greatly appreciated
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
The Game Boy Advance doesn't use a backlight, which can make it hard to see the screen in low-light conditions. If you are willing to take apart the GBA and use some tools, there many backlight modifications on the web that can be used to help install a backlight into your GBA. But you must keep note: by installing a backlight mod into the GBA, you must do it correctly, as you could cause damage to your GBA if done incorrectly. You will need some tools, and a soldering iron, for the task.
Punteggio 2
Aggiungi la tua risposta
Lee Wheller sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 76
Tutti i Tempi: 2,486
