Salta al contenuto principale
Introdotto nel 2017, è stato il modello flagship dell'azienda identificato con il nome di Sagit. Monta lo Snapdragon 835 accompagnato da 6 GB di ram e GPU Adreno 540
Mi screen working problem.
My mi 6A phone half upper screen is not working.
Questa è una buona domanda?
Punteggio 1
4 Commenti
my phone turns on and off by itself.what could be the problem?
da
Yas sar not working
da
hp yang mati layarnya, dicas cuma bergetar
da
LAYAR PONSEL mi 6A mati, kalau dicas cuma bergetar
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi Poorav,
Sorry to hear about your phone. Those kind of display issues are almost always a result of the LCD or the touchscreen failing (it's not clear from your description which problem you're having), but the fix is the same either way; you're going to have to replace the screen in order to get it working again.
I'm afraid iFixit doesn't have a guide for your phone to show you how to do that repair, but luckily there's a Spanish site called Nadie Me Llama Gallina that has exactly what you need.
Manuales / Xiaomi Mi6 / Full screen with frame
The screen itself is easy enough to get and is relatively inexpensive; I usually start with sites like Amazon, eBay and AliExpress depending on how quickly you need the part vs. how much you're willing to pay. Here's the first one that came up on my rather cursory search.
Original Mi6 LCD For Xiaomi Mi 6 Display With Frame 5.15" Mi 6 LCD Fingerprint Display Touch Screen Glass Panel Assembly - AliExpress
Note that you can buy the screen with or without the frame already attached; in general the price without the frame is marginally cheaper, but doing it with the frame is the generally recommended way, and the instructions I linked to are indeed for replacing the screen plus frame assembly. Doing the screen alone requires a different set of instructions; you can generally find those on YouTube if need be.
Good luck; let us know how your repair goes, and be sure to ask if you have any questions.
Punteggio 2
Aggiungi la tua risposta
Poorav Kumar sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 28
Tutti i Tempi: 1,594
