Salta al contenuto principale
2,26 o 2,4 GHz / Telaio unibody in plastica bianca
MacBook HDD+battery problems
so i just fixed this MacBook and the MacBook sometimes stops charging,before this it was water damaged,now after replacing the broken chips,the HDD sometimes stops working randomly and sometimes the battery stops,battery,HDD or motherboard? please answer i dont have any computers other than this to do some data transfer stuff between 2 phones using it so yeah
Questa è una buona domanda?
Punteggio 0
1 Commento:
@kaancan tell us more about the repair. What chips did you replace? What is the 820-xxxx number on your logicboard?
da
Aggiungi un commento
1 Risposta
See if the onboard diagnostic offers a clue, restart your system and press the D key to enter Mac startup key combinations
I would install this gem of an App CoconutBattery depending on your OS you may need to email them to get the older version.
What’s important is the battery has a lifespan, you may need to replace it. Review this Apple TN Determine battery cycle count for Mac laptops
Let us know what you discover as you need to dig a bit to know which pathway you need to go.
Punteggio 0
1 Commento:
now there is a bigger problem, it now gives a white screen and sometimes a missing folder icon and yeah, i got a newer computer
da
Aggiungi la tua risposta
KAAN CAN sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 10
Tutti i Tempi: 266
