Salta al contenuto principale
The Expression Photo XP-960 wireless, wide-format Small-in-One printer puts professional-quality photo printing at your fingertips.
Replace waste ink pads
My Epson XP 960 display warned that the printers waste ink pads are at the end of their life cycle and needed to be replaced. I ordered and installed a new a complete ink pad kit but the printer still prompts that the ink pads need to be replaced. The installation was done correctly but the printer is stuck on the warning .
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Risposta più utile
@pauljustyna see if this video will help you out. It may be possible that you need to reset the waste ink counter after having replaced the waste ink pad pads. See if this procedure will resolve this.
Punteggio 2
Furthermore you need to reset the waste ink tank counter via software, with WIC or another similar software.
Punteggio 0
1 Commento:
@jallroad that is correct. The video actually makes mention of it and shows how to install it.
da
Aggiungi la tua risposta
Paul Justyna sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 25
Ultimi 30 giorni: 100
Tutti i Tempi: 2,346
