Disk read error occurred
My laptop has ran into a error where the disk can't be read, I pressed f2 and I don't know how to reset/reboot it, non of the "Boot priority orders". Help me please
Questa è una buona domanda?
First of all - can you see the hard drive in the BIOS? If 'yes' then try the Windows recovery environment:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 will open into the Advanced Start-up environment
· While in the Advanced start-up environment, use the following steps to use Start-up Repair:
You could also try running 'chkdsk' command look in advanced options
From CMD Prompt
Run following:
Chkdsk /F
If that doesn't work you may need to run a drive sector recovery software.
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 34
Tutti i Tempi: 384
