Power steering not working
Questa è una buona domanda?
Check the fuse located under the dash for your electronic power steering module. If it's okay, then check the harnesses for the module itself for bad connections or corrosion on the terminals. If there are no bad connections, you'll have replace the EPS module itself more than likely.
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 23
Tutti i Tempi: 531
