SNES won’t power on
I’ve changed the Pico fuse, the power supply and barrel jack work, and so does the switch… I turn it on and I get no light… any ideas?
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 194
@aaronjosep48927 Do you have a multimeter?
da Andrew S
@andrewsawesome ya I checked pretty much everything
da Aaron Josephson
@aaronjosep48927 Did you check to make sure that the voltage regulator is working properly?
da Andrew S
@andrewsawesome I actually did not where is that located and how do I check it?
da Aaron Josephson
@aaronjosep48927 Turn your multimeter to the 20 VDC range (if you need help with this, upload a picture [ Aggiungere immagini ad una domanda ] of your multimeter and reply to this comment). Plug your power brick into the wall, then into your SNES. Find a component labeled "U12" or "IC12" on the motherboard. Touch the black probe to the middle pin and touch the red probe to either side. You should have about 10-18 volts on one side and 5 volts on the other. Let me know what voltages you get.
da Andrew S
Mostra altri 6 commenti
