Salta al contenuto principale
Il Samsung Galaxy A33 5G è uno smartphone di fascia media rilasciato da Samsung il 20 aprile 2022.
My phone screen problem
  • My phone unable to display screen even touch screen with thumb are not working some local technician recommend me to buy and change with new screen but I still did not believe them because I assume the problem is power bottom as there is sound when I plug it to charger
Questa è una buona domanda?
Punteggio 4
4 Commenti
The screen do not have any broken sign even any scratch on it so how can it be the problem is with screen
I Guess problem may be from power bottom
da Condividi
da Condividi
Samsung a33 mother board repair
da Condividi
My phones touch from upper side is not working rest of aĺl touch is working problem
da Condividi
Aggiungi un commento
3 Risposte
Soluzione prescelta
@yigremache79592 give us more background on this. for example, letting us know if your phone vibrates when you turn it on etc., is kind of important. Yes, for now and with the scant description provided, it does sound like failed display. Let us know why you think it is not.
Punteggio 4
1 Commento:
Yes it vibrate when its power is on
da Condividi
Based on what info you have provided, your technician is right. You can hear the charging sound because the phone still works on the inside, but the screen is broken. If you have any more questions, feel free to ask.
Punteggio 1
Punteggio 0
1 Commento:
Yigremachew, you're not listening to these experts who are telling you that yes, despite the fact that you don't see any scratches or cracks on the screen, the screen is still damaged and needs to be replaced. It is NOT a problem with the power button!
The screen has very delicate connections between the OLED display and the flex cable that connects it to the motherboard. Those connections can be broken easily when the phone is dropped or sometimes even from being bent if you keep it in your pocket and sit on it.
You now have three knowledgeable people who know what they're doing who are all telling you to listen to the technician and get the screen replaced. So either do that or continue to ignore good advice and insist we're all wrong and that it just has to be the power button. It isn't.
da Condividi
Aggiungi la tua risposta
Yigremachew Bereda sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 19
Ultimi 30 giorni: 62
Tutti i Tempi: 1,921
