Salta al contenuto principale
Informazioni sulla riparazione della stampante a getto d'inchiostro multifunzione wireless Brother MFC-J6920DW. Numero di modello: MFC-J6920DW. Disponibile su Amazon da settembre 2012.
printer paper does not load, please help
paper does not loaded while printing so i used back side but that back side to print is only accept 1 paper at time so its exhausting , the normal blank paper load does not work so i use that option , how can i fix this? so i can print 10+ times arow and not once a time using back-side of printer option . please let me know as soon as possible
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
@karimhalawi this is what you want to check on your printer first
Immagine
After that, it gets kind of tricky and way to much to write on here. I suggest you get the SM Brother MFC J3520 And Others and use the steps on page 88 to determine what is going on with your printer.
Punteggio 0
1 Commento:
thank you sir, i will try out and let u know
da
Aggiungi la tua risposta
karim halawi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 2
Tutti i Tempi: 220
