Salta al contenuto principale
La HERO6 Black è stata presentata il 28 settembre 2017.
Device is not charging
Hi! I have problem with my Hero 6, It's not charging but It can be turned on by plugging a charger, without charger it does not
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hello @johngilbert9992! Have you already tried another battery? If the battery is failed it might explain why it won't power on without a charger, also, what % does the battery show up as when the camera is plugged in, if any? Thanks! :>
Punteggio 0
2 Commenti:
Hi! Yes, I tried changing the battery but nothing change, turns on only if I plug a charger even without a battery inside and its show electrical plug charging indicator i think ^^
da Condividi
@johngilbert9992 Ah ok no worries! Have you already tried factory resetting the GoPro? I think there might be a setting somewhere that sets it to only use mains power? Or i could be misremembering, I use GoPros a lot myself, but I use a Hero 9 not a Hero 6. Thanks!
da Condividi
Aggiungi la tua risposta
jjsoliveres2712 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 643
