Salta al contenuto principale
Guide di riparazione e informazioni sullo smontaggio del rivoluzionario smartphone pieghevole di Samsung, il Galaxy Z Fold2, rilasciato a settembre 2020.
Inside screen not working
When inside screen is folded out it doesn't work . Only works on front screen.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Risposta più utile
Sounds like your inner screen has failed and needs replacement. Samsung took a screen and "designed" it to fold when it really shouldn't be folded over and over again. These OLED screens are already difficult and expensive to manufacture as is, now they just added a layer of complexity and even more wear and tear all while charging more.
Punteggio 1
Does is it function the same if the inner screen is not working
Punteggio 1
1 Commento:
Yes it does.
da Condividi
I need inmer display change
Punteggio 0
What it cost 2 fix 2 unlock it n the screen n where can I take it living brantford Ontario
Punteggio 0
2 Commenti:
The bottom half of the screen n 2 unlock
da Condividi
It's broken and won't turn on and the bottom half of the screen won't work
da Condividi
in fact, Foldable screens have a high failure rate. replace the new
Punteggio 0
Inside is black and outside is working
Punteggio 0
Aggiungi la tua risposta
Vici sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 47
Tutti i Tempi: 1,467
