Salta al contenuto principale
Il BDV-NF620 è un sistema home theater all-in-one di Sony. L'unità principale funge da lettore Blu-ray/DVD/CD, sintonizzatore e ricevitore A/V, il tutto combinato in un unico dispositivo.
PUSH Protect error message
I have BDV-N580 bluray player when turned on I'm getting a display message as PUSH PROTECT and the display is not changing to other menu options when operated manually or through the remote.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@subramanin sounds like your BR player has gone into power protect mode. When that happens you pretty much cannot access anything on your player until the error is cleared. Try a rest first. For a reset remove everything that is plugged in to it and let it sit for an hour or so. Now, I am not familiar with your model so I can not tell you if there is a reset button. Some Sony's have a reset button or a reset hole (insert a paperclip into that and hold for 15-30 sec to reset).
ALways make sure that everything plugged in makes proper connection and check your power cord etc. If a reset does not work and it continues to display the message, it may be time to disassemble it and check the power supply etc.
Punteggio 0
Aggiungi la tua risposta
SUBRAMANI N sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 24
Tutti i Tempi: 329
