Salta al contenuto principale
Il Galaxy A11 è uno smartphone Android di fascia medio-bassa rilasciato da Samsung a maggio 2020. Identificabile dal numero di modello SM-A115 (seguito da caratteri relativi alla variante o all'operatore).
Ear speaker not workig
My samsung galaxy A11
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@kidusmarkos make sure that all your software is updated (check in settings) and that your speaker is turned on and that the volume is up. Check to make sure you have sound when you connect some earphones. It is possible that this is a bad jack, a bad speaker or a board issue.
Since iFixit does not yet have a guide for this, use this video to replace the speaker.
You can also use the Samsung repair flowchart for the speaker.
Immagine
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Kidus Markos sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 8
Tutti i Tempi: 366
