Salta al contenuto principale
Il controller V2 è disponibile in diverse generazioni. Stai guardando la Generazione 4.
R2 button not working
So recently I replaced both joysticks on my controller and since I did this the R2 button does not work. I cleaned the contacts, tried to replace the mylar but still nothing. The L2 button is triggered when I touch the joystick contacts with my finger. Can anyone help?
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
I think we'll need to see pictures of the inside to answer this the most effectively. Feel free to add some to your original post.
This could just be some parts aren't quite aligned properly, or it could be there is some damage to the giant flexible cable that carries all the button signals.
Since replacing the joysticks requires soldering, we'll also want to see pictures of your work to be sure nothing on the board is amiss.
Punteggio 1
1 Commento:
I just posted a photo if you can take a look
da Condividi
Aggiungi la tua risposta
Denis Fluturas sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 23
Tutti i Tempi: 1,097
