Removing oil pan gasket
How do you remove oil pan gasket on a 96 Camry le v6
Questa è una buona domanda?
Does it have the 1MZ-FE engine?
If so according to the IMZ-FE engine section for a 1994 Camry, there are two oil pans in the engine.
Click on the magnifying glass icon in the header bar of the document and type "oil pan" (without inverted commas) in the search box to find all the references to the oil pans then click on the arrows to go through the list
Note: The website linked can be a bit temperamental. If it doesn't load the document, you may have to refresh the browser page (maybe a few times, - if using a Windows PC press F5 but do it one at a time and check) but it does work.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 17
Tutti i Tempi: 121
