Salta al contenuto principale
Stampante multifunzione con serbatoi di inchiostro integrati per una stampa a colori rapida, conveniente e affidabile, inclusa una fornitura di inchiostro per due anni
Red light blink not print..
Repair this device please help me to repair this printer problem
Questa è una buona domanda?
Punteggio 8
1 Commento
@susanta48194 which red light blinks and does it blink in a pattern? Did anything happen to the printer that may have brought this on? What have you checked?
da Condividi
Aggiungi un commento
3 Risposte
Soluzione prescelta
I believe it said your inkpad is at the end, contact support.
If this is your problems, then replace your inkpad first otherwise your ink waste will flooding the printer.
Search for adj.prog for L310, download it.
Disabled your antivirus for a while.
Rund this program choose your printer type and ports.
Click waste ink counter reset.
Don't forget to choose check first (Menu) before resetting it.
Hope this will help to resolve your problems
Punteggio 6
1 Commento:
It will start picking up paper but stops picking the paper
da Condividi
Epson l130 printer 2 red light bling
Punteggio 2
epson l360 printer lining print out problam
Punteggio 1
Aggiungi la tua risposta
SUSANTA sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 50
Tutti i Tempi: 2,095
