Salta al contenuto principale
The VLT 1000 desktop fan has four blades with a diameter of 30 cm. It is made of stainless steel and has 3 speed settings.
9 Domande Visualizza tutte
Electric wire burn want to replace with new wire.
Want to replace new wire so help me with main neutral and earth connection
Questa è una buona domanda?
Punteggio 1
2 Commenti:
@ivaanmaran67435 post some pictures of where the wires are connected now. That way we can see what you see and hopefully help you with that. Aggiungere immagini ad una domanda
da
I agree Ivaanmaran above. Question. Did the wire burn occur on its own or was the cord next to an hot object?
da
Aggiungi un commento
1 Risposta
Dear Ivaan Marandi and Eva Marandi,
If your cable is not compatible with the voltage you need, please try replacing it with a cable that matches the required voltage. Additionally, consider changing the fuses in the cable socket and try again.
Punteggio 0
Aggiungi la tua risposta
IVAAN MARANDI AND EVA MARANDI sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 71
