Salta al contenuto principale
A1708 / EMC 2978 — Rilasciato a ottobre 2016, questo MacBook Pro entry-level mantiene i classici tasti funzione (al posto della Touch Bar OLED). La versione con tasti funzione monta un processore Intel Core i5 e due porte Thunderbolt 3.
Screenless mod? Is making the MacBook screenless difficult?
I've seen two YouTube videos but felt that there could be a better tutorial. My screen is broken. I'm using a monitor to use it but would be happy to remove the screen and use a portable monitor.
Anyone have any experience?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Sadly there’s a lot of wacky stuff out there!
It took us a good three years trying to educate people about using Rice to dry out a cellphone! It doesn’t work! Don't Put Your Device in Rice. Here's Why...
So let’s look at this objectively!
The display has a bunch of functions, you know the first! Display, the next a camera. But there’s more! The lid holds magnets! One is used with a magnetic sensor (Hall Sensor) to wake and engage the system. It also offers when off the display of the battery state.
The last one is a killer! Input to SMC which when severed goes into CPU safe mode where the fan is boosted and the CPU’s clocking is reducedreducing the systems performance!
So them’s the facts! Apple design precludes running without the display being present and wired!
So can I over come all of this? I’m sure someone has tried, in the end of all of the alterations and the invested time it’s just better to live with an external display as well as keyboard and mouse!
Or, see if you can find a used display to fix your system MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and the guide Sostituzione gruppo schermo MacBook Pro 13" Function Keys Fine 2016
Immagine Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.
Prodotto
$349.99
Punteggio 3
2 Commenti:
Wow. Thank you so much for the thorough and detailed response. Honestly you haven't just given me the best answer, you've also managed to console me that this isn't a big deal and the mac is still usable.
Really appreciate it.
da
@quimper - Sorry I burst the bubble on you. Please accept the answer. Thanks!
da
Aggiungi la tua risposta
Quimper sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 12
Tutti i Tempi: 621
