Hi @christianux1711
If the phone is a OnePlus Nord 2 (DN2101 DN2103) model, search online for 1041100145 to find suppliers of the power button flex cable.
There's also 1071101124 which some suppliers show as the power button and others show as the power button bracket, but images of it (when there are some included by the suppliers found) look more like a bracket.
Hopefully this is of some help.
Wenn es sich bei dem Telefon um ein OnePlus Nord 2-Modell (DN2101 DN2103) handelt, suchen Sie online nach 1041100145, um Lieferanten für das Power-Button-Flexkabel zu finden.
Es gibt auch 1071101124, das einige Anbieter als Netzschalter und andere als Netzschalterhalterung anzeigen, aber Bilder davon (wenn einige von den Lieferanten gefunden wurden) sehen eher wie eine Halterung aus.
Hoffentlich hilft das etwas.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
369 / 1500
== Übersetzter Text ==
Thanks for the quick help! I ordered a power key, but unfortunately it is not available. I have the whole thing with some aluminum foil gefixt, unfortunately, the button is also broken off on one side afterwards and I had to take more aluminum foil and a tight-fitting protective cover, so it goes reasonably. I will have to sell the north...unfortunately
da Christian “Uxo Buxu” Teichert
