How to replace screen
Questa è una buona domanda?
@singgsirya iFixit does not yet a guide for this. Use the one from here to replace your screen. Since we do not know where you are located, I suggest an online search for a replacement screen within your part of the world.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Display change
And power bottom change
I'm going with the assumption you meant "button" rather than "bottom", because the phrase "power bottom" has a whole different meaning in this country than what you probably intended.
If you need to change the electrical part of the button including the click dome, use this guide.
https://www.nadiemellamagallina.com/en/m...
If you want to replace the physical part of the button that you press, use this one.
And see @oldturkey03's answer for the guide to replace the screen.
Mobile no the wrking
Mobile display no werke
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 33
Tutti i Tempi: 1,303
