Salta al contenuto principale
Smartwatch Motorola Moto 360 2nd Gen prodotto da Motorola Mobility nel 2015. Smartwatch indossabile che si collega al tuo telefono.
Touch Screen not working and function
Hi, I have a motorola 360 2nd generation watch, my watch has a problem with the touch screen not working but the watch is still working fine, only the screen does not work and when touched it does not move, it happened after the system update, I hope you can help me to solve this problem, your cooperation is preceded by a thank you
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Change the panel and if not working then spilt out
Punteggio 0
Well try to try resetting the device to its factory settings. It can be help in fixing the issue.
Punteggio 0
Aggiungi la tua risposta
raja atikah sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 11
Ultimi 30 giorni: 38
Tutti i Tempi: 388
