Salta al contenuto principale
Un giradischi rilasciato da Audio-Technica nel 2019.
Start button is not doing anything
The belt is on correctly, and the manual reset did not help. The start button does nothing; almost as if there’s no power.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta più utile
This is the best site for turntables I have been able to find:
Turntables, Tonearms and Cartidges
Punteggio 1
1 Commento:
Appreciate it! It looks like it might be a bad motor, so I'm probably in a position to replace, but I'll bookmark the site.
Cheers
da
You may need a multimeter to check if the motor itself is dead. If it is the motor, the replacement may be available via Audio-Technica directly. The part is weirdly hard to find online otherwise. you can contact them via email at parts@atus.com. (If in the USA, check your regional Audio-Technica site for a parts page otherwise.) It will, however require a bit of soldering to replace as two of its wires are connected to another board directly instead of via a push connector.
You can see details as to how to do this in this guide for its predecessor: Sostituzione motore Audio-Technica AT-LP60BK
The internals are the exact same between the LP-60 and the 60X layout-wise. AFAIK the only major changes were in the physical appearance of the turntable. I would not recommend de-soldering while the motor is still in the unit (as in that old guide) as the entire shell is plastic. It's also just a big unit, which you already know due to owning one. It'd be annoying to work on it like that.
Does it indeed make a mechanical "click" when start is pressed?
Punteggio 0
Aggiungi la tua risposta
Jeremy R. Stoll sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 20
Ultimi 30 giorni: 107
Tutti i Tempi: 5,502
