Salta al contenuto principale
Il Razer Blade 15" Base Model (2020) è un potente portatile da gaming, dotato di un processore Intel di decima generazione a 6 core da 5,0 GHz.
Adding USB-C charging option externally
I've seen some adapters around that connect to Razer's proprietary connector, and was wondering if anyone has attempted to use a USB-C PD board to charge the laptop? I mostly use my laptop portably in Linux without use of the discrete graphics so I only require <100W of power which USB-C can provide. But unsure whether the charging port will accept less than the 230W that comes from the regular charger
Questa è una buona domanda?
Punteggio 0
1 Commento:
Would love an update on this!
da
Aggiungi un commento
1 Risposta
@lachlanhogan It depends how razer has their power management set up, with other brands such as Dell they force the CPU to throttle a huge amount if it's not connected to the correct power supply, either you'll get lucky or it won't be usable unfortunately.
Thanks! :)
Punteggio 0
Aggiungi la tua risposta
Lachlan Hogan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 32
Tutti i Tempi: 1,121
