Salta al contenuto principale
La Bajaj Discover è una marca di motociclette di Bajaj Auto. Attualmente esistono quattro varianti della Discover: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST e Discover 150 DTS-i.
Start problem Bettry full charge Handle problem Kick problem
  • Start problem
  • Bettry full charge
  • Handle problem
  • Kick problem
Questa è una buona domanda?
Punteggio 7
4 Commenti
Start problem repairing
da
@sameertagala @vaibhavtaliyan we really need more history than just 3 words. If you are seriously wanting some help, you need to be more descriptive. At minimum we need to know what Bajaj model your bike is. Complete model number please. Then we need to know what the actual starting problem is. Then you need to tell us what you have already tried to fix this. Give it a try. You'll see that people will actually work to find a solution for you. We just have to know what the problem is.
da
Excilater not work bike cut out always
da
@parmmehmi what year, make and model? what have you checked? Since it cuts out, it could be related to your carburetor, the ignition or the fuel supply.
da
Aggiungi un commento
4 Risposte
Risposta più utile
Start problem solve for bike pulsar
Punteggio 2
If you are facing starting problem in pulsar So there is chance of problem in CDI coil, spark plug , spark plug cap, petrol Over flow and engine head.
Before you spend any money first try on petrol Over flow, you just do off petrol cock when you park your bike and when you go back on bike then on this cock.
If you will not get result then check spark , plug and current and do work on CDI.
Punteggio 1
Are you getting a spark from your plug when you put it against cylinder head, have you tried putting 5 ml petrol into cylinder head
Punteggio 0
{Bike's Solution}
1: Bike ka pulk saaf kare pahle
2:Air filter ko saaf kare
3: air mixture 🔩 ko set kare
Punteggio 0
Aggiungi la tua risposta
Sameer Tagala sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 29
Tutti i Tempi: 2,643
