Salta al contenuto principale
La seconda generazione della Rogue è una versione della Nissan X-Trail, ispirata alla Hi-Cross Concept per adattarsi al mercato nordamericano.
Power seat not working
My driver seat is powered and will still go up and down but won’t go forward or back? Not sure what could be wrong.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta più utile
Hello! It's possible that you have a malfunctioning track motor or one of the wires to it was damaged. That's where I would start.
Punteggio 1
@mecca92183 besides the prior answer, I would go through the SM that deals with the Seats and test the wiring. I have the one for the 2016 model but this should pretty much apply to the ones from 2013-2020. 2016 Rogue Seats Check if you have power to it and check the connectors with a test light, to see if your motor control works. If all of it checks out, it's possibly the motor. Again, you will have to go through the troubleshooting.
Punteggio 0
Aggiungi la tua risposta
Mecca sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 45
Tutti i Tempi: 1,795
