Salta al contenuto principale
Pubblicato a giugno 2017 come successore del Surface Pro 4. Noto anche come Microsoft Surface Pro da 12,3". Numero di modello: FJT-00001.
Replaced Battery, this is what I got..
Was wondering what I broke here? I was very careful and it seemed to be okay when I replaced the battery and reassembled it.
The screen is not cracked, but I was wondering if it was a connection issue. However, why would just a strip display like this?
Immagine
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
I am sorry to say this James, and others can chime in here if they disagree, but I'm pretty sure that screen is dead.
There's a chance it is a connection issue. Did you try reseating the cables? But if not, it is likely a separation issue where the screen was pulled apart and the layers through which the data connection flows were separated at some point.
It is not exactly your fault, Microsoft has made these things as hard to service as possible (they earned the lowest possible repairability score for a reason), and no matter how careful you are screen issues have been known to happen on Surface devices.
Punteggio 1
Aggiungi la tua risposta
James Buchanan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 9
Tutti i Tempi: 279
