minimum wire mm for 3 kw load
What minimum mm wire (aluminium) should be used to carry a load of 3 KW to house?
Questa è una buona domanda?
Hi @adarshmohanty,
What voltage supply being used?
Power (watts) = voltage (Volts) x current (Amps).
You have supplied the power value (kW) and not the supply voltage value, but it is the current value (Amperes) that has to be known when determining the cable size i.e. A=P÷V e.g. 3000W ÷ 230V = 13.04A or 3000W ÷ 120V = 25A
Also the type of cable insulation is important as well.
Here's a link that may help.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 73
