Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e soluzione problemi per l'Apple iPad di nona generazione con Wi-Fi, disponibile con 64 o 256 GB di spazio di archiviazione. Rilasciato a settembre 2021. Identificabile dal numero di modello A2602.
Charging port not working
How do I find someone to replace a charging port on an iPad 9th generation?
It was working when it fell off the bed.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
3 Risposte
Risposta più utile
First of all, if you're looking for suggestions you'll need to tell us where you're located, as this is a worldwide site and the answer will be very different depending where you are.
Until then, all I can say is you're not in a good position here. Apple did you dirty on the charging port of your iPad; not only is it attached directly to the motherboard so you can't just replace a part, but they also put it on a flex cable, making it even harder to replace. So it's going to take a fairly skilled technician to be able to do the specialized soldering required to fix your port.
You can always do a search for local repair facilities and contact them. Ask whether they have the expertise to repair your port, and what the cost is.
Punteggio 2
it stopped working then i had to fix the charging port.
Punteggio 1
1 Commento:
Same. I Suggest To get an IPAD 9 Lightning Replacement.
da
ipad 9 no charging flex change ic change no charging
Punteggio 0
Aggiungi la tua risposta
Dan Frain sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 39
Tutti i Tempi: 1,806
