Salta al contenuto principale
Informazioni sulla riparazione dello smartphone LG G7 ThinQ. Pubblicato a giugno 2018. Numeri di modello: G710EAW, G710N, G710EM, G710AWM, G710EMW, G710TM, G710ULM, G710VMX, G710PM, G710VM.
Fingerprint scanner not working
Fingerprint scanner used to worked but over a period of time it slowly stop working.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
@jermainepinto sounds like it's time to replace the scanner. This guide should get you where you need to be, to replace the scanner. The scanner flex cable is readily available at many places. Just do an online search for something close to where you are.
While you work on your fingerprint scanner, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Jermaine Pinto sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 25
Tutti i Tempi: 343
