Salta al contenuto principale
The Aroma Diffuser produces mist and comes with lighting modes— high and low.
Why did my Muji diffuser suddenly stop working?
I’ve had this large aroma diffuser from Muji for a while now and it suddenly stopped working recently. I cleaned it thoroughly (inside and outside) but it’s not turning on. The light isn’t working either. Please help me. Light and mist both stopped working.
Questa è una buona domanda?
Punteggio 1
1 Commento
@ettore26292 Does this diffuser use an internal or external power supply?
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @ettore26292
If your diffuser is model number HAD-001-GLW-A0 check that there is 24V DC on the output plug of the power adapter that is used with the diffuser.
If the adapter is OK here's a teardown video that shows how to disassemble the diffuser so that access to the motherboard is possible.
Once you have access to the board and if nothing obvious is wrong, post some close up images back here so that others may see.
Here's how to add images to your question in ifixit Aggiungere immagini ad una domanda
Punteggio 1
Aggiungi la tua risposta
Ettore sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 18
Ultimi 30 giorni: 68
Tutti i Tempi: 2,663
