Salta al contenuto principale
Guide di riparazione, informazioni sullo smontaggio e sulla soluzione problemi per l'iPad Apple di decima generazione, disponibile nelle versioni Wi-Fi e cellulare con 64 o 256 GB di spazio. Rilasciato nell'ottobre 2022. Identificabile dai numeri di modello A2696, A2757, A2777 o A3162.
Heating issue/screen brightness effected
Could it be possible to give me the dimensions of where the logic board is so I can place some heatsinks to try and keep ipad cooler so the screen don't keep reducing brightness. I'm sure it's a heat issue as once temperature is reduce the brightness of screen returns to normal.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Here's a picture of the iPad 10 without the screen. I've marked out the logic board in the picture; basically if you cool the right edge of the iPad that's where the heat is going to be coming from.
Immagine
The picture is oriented so you'd be looking at it with the charging port on the bottom.
Punteggio 4
2 Commenti:
cheers. Planning to use akasa double-sided thermal conductive tape. I have plenty of small chipset blue heatsinks that should help handle the heat. Poor cooling design on expensive device. Apple solution is to close down apps to reduce processor usage which bring down heat.
da Condividi
@robmods you might want to consider using a 0.3 mm Copper Shim Thermal Pads and some Kapton Tape with your heatsinks. Typically these are used for copper modding graphics cards, but I'm willing to bet that they would work really well in your iPad.
da Condividi
Aggiungi la tua risposta
Robmods sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 532
