Salta al contenuto principale
Processore dual-core Intel Core i5 da 2,6 GHz (3,2 GHz con Turbo Boost) con 3 MB di cache L3. Lanciato il 13 febbraio 2013.
New screen camera not working
I swapped a screen from a Macbook Pro A2251 and installed it in a MacBook Pro A1708, the screen works as expected but the camera isn't working saying camera not detected in all applications. I have checked all the connections and reseated them. Should this setup work and what connection is for the camera?
Questa è una buona domanda?
Punteggio 0
2 Commenti:
@jasonmullan - Where did you purchase it?
da
I got it from a friends busted machine
da
Aggiungi un commento
1 Risposta
A2251 refers to a MacBook Pro (13-inch, 2020, Four Thunderbolt 3 ports), and A1708 refers to either the MacBook Pro (13-inch, 2016, Two Thunderbolt 3 Ports) or the MacBook Pro (13-inch, 2017, Two Thunderbolt 3 Ports). The display from the 2020 MBP is not fully compatible with the 2016 and 2017 models. Although the display portion will function, the camera will not. In order to have a working camera you will need to install a fully compatible display. Check this page for further information.
Punteggio 0
Aggiungi la tua risposta
Jason Mullan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 375
