Salta al contenuto principale
Il GameCube è la quarta console videogame di Nintendo. La riparazione è semplice e richiede solo strumenti di riparazione comuni.
Disc will stop spinning
My discs will initially start and load up, I can play for a few minutes. Then the disc will stop spinning during game play. I’ve tried cleaning the lens to no avail. Curious if this sounds like a fixable issue? Has happened with multiple games.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Rather than typing them all out again, this thread has a number of potential solutions to the issue you are having, hope this helps!
Disc not spinning in GameCube
Punteggio 0
This is a very common problem with all disc drives, the disc motor bearings get a tiny bit tight and it doesn't rotate at sufficient speed to recognise the disc, trying adding a tiny, very tiny! bit of oil to the disc motor bearing and see if it works
Punteggio 0
Aggiungi la tua risposta
M Doe sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 20
Tutti i Tempi: 694
