Salta al contenuto principale
How do I open the case?
I have an old Dell Latitude C400 that has some internal problems, either no fan or one that doesn't work, no USB port and the card slot needs to be replaced. I've been told that there are some kind of latches under two of the number keys (At this moment I don't exactly remember which ones) and I have to release those to open the case. Well, I think I found the spots, but pressing those spots doesn't open the case. What am I doing wrong and how do I remedy the situation and finally get the case open so I can see if I can fix the internal problems?
Questa è una buona domanda?
Punteggio -1
2 Commenti
IDK how you found the repair manual! I couldn't.
THANK YOU!!!!!! Hope it shows me what I need. 2 T-U. (Thumbs up)
da
You are very welcome. Thanks for accepting my answer and all the best to you.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
Ashtin Righter, download the service manual for your computer from here. It will show you how to disassemble it properly. Hope this helps, good luck
Punteggio 2
Aggiungi la tua risposta
Ashtin Righter sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 16
Tutti i Tempi: 876
