Salta al contenuto principale
Informazioni sulla riparazione e lo smontaggio delle cuffie da gioco wireless G533 di Logitech. Le G533 possono essere identificate dal numero di modello A-00072. Sono state rilasciate nel gennaio 2017.
Mic randomly stopped working
I can hear the beep which indicates my mic is being turned on when the mic is flipped up to mute and down to unmute. Although i hear the headset is registering the mic being used for some reason, it just stopped working.
does anyone have experience replacing the mic on one of these? if so please share your experience and point me in the right direction for replacement parts.
thank you in advance.
Questa è una buona domanda?
Punteggio 3
1 Commento
I had the same issue with 2 Headsets I bought used. One had this from the moment I bought it, the 2nd worked fine for about 1 year.
I guess the problem is a cable failure in the lever mechanism
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi HawgDawg,
I was going to answer, but ran across someone else with a similar problem and the first comment on that question was pretty much exactly what I was going to say, so I'll just link to that question and let you read it for yourself.
Mic doesn’t work - Logitech G533 - iFixit
See the comment by F Dryer (@notbroken ) for a very good explanation of exactly what I was thinking.
Punteggio 2
1 Commento:
Thanks for the reply Jerry
I can't seem to find the comment you're referring to, the thread you linked was helpful though.
da
Aggiungi la tua risposta
HawgDawg sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 55
Tutti i Tempi: 3,649
