Salta al contenuto principale
Prima generazione dell'utilitaria supermini di Citroen.
Transmission not selecting reverse
Hi, I have a 2002 c3 that won’t go into reverse? It runs fine in forward gears but won’t select reverse gear. Any advice would be much appreciated. I am located Gold Coast Australia.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
@c3user I am assuming it's an Automatic. This sounds like an issue with the selector, bad cable, bad adjustment or a bad solenoid in the valve body. For now look through this part of the SM Citroën C3 2002 Gearbox that deals with identifying your transmission and how to adjust the selector etc. Let us know what you find out. You can always add pictures to your QUESTION in case you come across some oddity. Citroen for sale in Australia? That is pretty cool.
Punteggio 2
1 Commento:
Thanks oldturkey03 I’ll definitely check it out and keep you updated on the progress. 👌🏽
da Condividi
Aggiungi la tua risposta
C3user sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 45
Tutti i Tempi: 1,617
