Do I have a freezer thermostat issue?
Hi everyone,
Looking for some help here. I have a Danby stand up freezer that just completely goes warm and dead on me. However if I play with the thermostat the motor kicks in. So I'm thinking it's the thermostat that needs to be changed. However i tested the thermostat for continuity and it's seem fine. Any suggestions? Can it be a defective thermostat despite having continuity?
Update (04/05/23)
I meant Tested the thermostat.
Questa è una buona domanda?
6 Commenti
Hi @uvfvb50vflmba,
What is the model number of the freezer?
da jayeff
@jayeff The model is a Danby DUF808WE.
da marco.cascini78
Did replacing the thermostat fix your issue? I'm having the same problem with the same model freezer. Have a thermostat and start relay on order.
da Paul Mykytka
Hi Marco,
I have the same model Danby WUF808WE, what screwdriver did you use to take the thermostat cover off with? Seems to be a special type and I can’t seem to locate one.
Cheers,
AJ
da YVRAJ
Hi Marco,
Cheers,
AJ
da YVRAJ
Mostra 1 altro commento
