Salta al contenuto principale
Una versione della console videogame Nintendo Switch piĂ¹ economica e pensata esclusivamente per l'uso portatile, con controller Joy-Con integrati e uno schermo leggermente piĂ¹ piccolo. Pubblicata il 20 settembre 2019.
How to remove joystick caps
Immagine
I have ordered new joysticks for my lite, but wanted to know if it was possible to remove the original joystick caps?
I have a pokemon edition lite with the non standard joystick colors and they are still in mint condition (minus drift). So was hoping to move them to the new joysticks.
Update (03/26/23)
No amount of pressure let the cap come off.
Seeing as the drift had already killed the joystick I decided to tear it down.
It appears that Nintendo has the stick and cap molded as a single unit in production, so its not possible to get the cap off to swap onto the new Guli sticks.
At best I might be able to get just the rubber cover off, but no idea if that would fit the Guli caps.
I am happy to have my sticks working again, but also sad that I am losing the unique coloring.
Questa è una buona domanda?
Punteggio 1
1 Commento:
You can't easily, it is actually glued on.
da
Aggiungi un commento
1 Risposta
You should be able to just pull them off once you have the joysticks out, but I've never even held a switch lite, so you might want to verify that
Punteggio 0
Aggiungi la tua risposta
Daniel Peregrym sarĂ  eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 65
Tutti i Tempi: 2,399
