Salta al contenuto principale
Informazioni e assistenza per la riparazione dei tosaerba a spinta prodotti da The Toro Company.
Front wheels not straight
On the toro 30” time master are the wheels supposed to look as they are leaning outwards and not straight? We haven’t even used ours yet , unloaded it yesterday and just want to make sure the front wheels are right before using it. Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Since it is new, it is possible that the bolts holding the wheels in are loose. In the center of the wheels, there should be a screw or bolt that needs to be tightened. If there is no bolt visible, look closer, as there may be a cover to keep grass out.
It is worth noting that I don’t have this exact model lawnmower, but most are pretty similar in design, so please take this with a grain of salt.
Punteggio 0
1 Commento:
Will definitely check that, thanks
da
Aggiungi la tua risposta
Amanda Chandler sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 10
Tutti i Tempi: 431
