Salta al contenuto principale
Riparazione e assistenza per i controller forniti con la PS3. Rilasciato a novembre 2007 (solo in Giappone) e nel 2008 (negli altri paesi), il controller alimentato da una batteria al litio con sensori di movimento (CECHZC2) è semplice da riparare.
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
Punteggio 0
9 Commenti:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
da
@thimstr I don't think so. Usb is purely for charging and not actual power.
da
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
da
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
da
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
da
Mostra 4 altri commenti
Aggiungi la tua risposta
Thim Strömberg sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 45
Tutti i Tempi: 1,839
