Salta al contenuto principale
Tablet Surface Pro di terza generazione, rilasciato il 20 giugno 2014.
Touch screen not working.
The touch screen isn't working. I purchased a Surface Pro with a bad battery and broken screen. Touch screen was working initially before screen replacement. I've tried two different screens so it doesn't seem to be a hardware issue. All of the drivers appear to be installed properly. I ran the hardware check and everything passed except the touch screen. Is there something I could've broken when replacing the screen and battery?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There could be missing components from the tablet's board, are you able to look closely around the display connectors to look for any missing parts?
Punteggio 0
1 Commento:
I don't see any missing parts. I connected everything that I disconnected when removing the original screen. Both ribbon cables are connected properly to the panel and the board.
da
Aggiungi la tua risposta
Zac sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 18
Tutti i Tempi: 302
