Salta al contenuto principale
Versione dell'Asus Zenbook Prime UX31A compatibile con touchscreen Windows 8
possible ways for upgrading the RAM.
Where can I find the compatible motherboards for ASUS UX31xxx models?
I have UX31E, already upgraded the SSD via an adapter but I'm trying to understand the possible ways for upgrading the RAM.
Thanks in advance.
Update (01/30/2023)
Could you find any solutions for upgrading the soldered RAM?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
@desideroali, On boards with soldered RAM, it’s only possible to “replace” with high level board work (micro soldering).
This is not a DIY task. It requires a lot of skill, appropriate tools / equipment, and a LOT of patience.
Punteggio 2
2 Commenti:
Thank you.
And what is your suggestion for accomplishing this? Any suggestions for repairshops or compatible hardware?
And even if this is done for UX31E, is the motherboard compatible with 8GB RAM?
da
@desideroali A reputable micro soldering shop should be able to do it, but be prepared to pay a fair bit for the job.
As for compatibility, all information I’ve found on the UX31E says it’s a maximum of 4GB. It’s not to say it isn’t possible, but unlikely.
da
Aggiungi la tua risposta
desideroali sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 18
Tutti i Tempi: 1,615
