Salta al contenuto principale
La quarta generazione del Chromebook 11 di HP, economico e da 11,6 pollici, rilasciato nel 2015.
How can I replace the storage?
If the internal storage is too low, what can i do to replace another large storage?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Hi @mbwilo_m
Short answer is you can't or not easily anyway.
According to the specifications the laptop has either 16GB or 32GB of eMMC storage.
eMMC storage is hard mounted onto the systemboard i.e. it is soldered to the motherboard
One option to consider is to insert the largest capacity SD Card that you can afford or want and insert that into the laptop's card reader and leave it there and use it for extra storage space.
Punteggio 1
3 Commenti:
And couldn't the operating system be installed on the other colocated storage?
da Condividi
@davoc352
Probably not. Most likely the BIOS bootloader won't recognize the SD card port as a boot option.
da Condividi
i use window 11 lite on my chromebook hp g4 now it storage can upgrade from market place of laptop repair so if you dont have enough money you should buy this try to find 4gb ram is better because ram can't upgrade in someplace and currently iam using parrot os
da Condividi
Aggiungi la tua risposta
Mishael Mbwilo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 43
Tutti i Tempi: 1,908
