Salta al contenuto principale
WiFi connection with Android
How can I get my Android phone Oppo F11 pro see the Drone Wifi signal? I have tried for the past 3 days and the drone doesn't seem to have it's wifi visible for my Android to see. I need help please. if there are preferred compactible phones I will like to know.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Did you check of your drone is accessible from other phones?
If so - check if your drone's wifi is 2,4 GHz signal and not 5 GHz, since if you have an older phone it may not properly support 5 GHz. Also if your drone has a wifi channel selection option - make sure it's a channel between 1 and 10 to keep it on the safe side. Hope this helps.
Punteggio 0
Aggiungi la tua risposta
Victor okechukwu sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 18
Tutti i Tempi: 453
