Salta al contenuto principale
Adattatore di alimentazione CA magnetico di seconda generazione per prodotti MacBook, rilasciato per la prima volta nel 2012. Non compatibile con i sistemi della generazione precedente. Disponibile nelle versioni da 45W, 60W e 85W.
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Immagine
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
Immagine
Punteggio 6
16 Commenti:
So the output from both Power pins must be around 20V?
I have 85W charger.
da Condividi
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
da Condividi
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
da Condividi
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
da Condividi
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
da Condividi
Mostra 11 altri commenti
Aggiungi la tua risposta
Yurii Chaikovskyi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 35
Ultimi 30 giorni: 155
Tutti i Tempi: 13,582
