Salta al contenuto principale
I portatili HP Envy 15t presentano le lettere “HP” in caratteri minuscoli al centro della cornice inferiore del display.
Blue screen of death
Hello I was using my laptop with no problem since I got it so I tried updating windows and it was stuck on %100 so I restarted my laptop thinking everything would normal ones it's on but I got the blue screen instead with critical process died stop code , I have tried everything but nothing works resetting,startup repair, uninstall updates nothing works but when I try system restore I have to tick a little box on the disk I'm using but I don't have a mouse pointer to tick the box, please help me.
Immagine
Questa è una buona domanda?
Punteggio 0
2 Commenti
@vybzonline update which part of Windows? Update to what?
da
@oldturkey03 I was updating the windows 10 because it was not up to date.
da
Aggiungi un commento
2 Risposte
Risposta più utile
How to fix a Blue Screen of Death on a Windows PC
Uninstall incompatible software.
Run a memory checker.
Check for hard drive errors.
Remove non-essential peripherals.
Replace defective or incompatible expansion cards.
Run Setup Diag after a failed Windows update.
Perform a clean install.
Regards,
Will
Punteggio 1
1 Commento:
Thank you for your reply
da
Hello I will suggest you the following.
  1. Use specialized BSOD repair software.
  2. Uninstall critical third-party programs.
  3. Run SFC.
  4. Check all drivers if any driver is outdated update driver.
  5. Backup your data and clean install Windows
Punteggio 0
Aggiungi la tua risposta
Abdul Malik Suraj sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 15
Tutti i Tempi: 369
