Salta al contenuto principale
The Xbox Elite Wireless Controller Series 2 was released on November 4, 2019, and is compatible with the Xbox One, X, & S consoles as well as PCs running Windows 10/11. Model 1797.
31 Domande Visualizza tutte
Used to not hold a charge so changed battery but not powering up now
So my controller did get caught in a flood but it was working fine aside from no longer holding a charge. I opened it up to replace the battery and now it is no longer powering on even after its connected to power. Is there any other parts that could be the cause? I see some slight corrosion on pins and I'm thinking the dirt and building in there was what was keeping it getting power.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@robertadams313 Yes, looks like a bit of corrosion, etc. you do want to completely disassemble your controller. Then remove the board and clean all of it with a high grade (+90%) isopropyl alcohol. Use something like this guide Riparazione danno da liquidi iPhone for the cleaning. It was written for an iPhone but all the points made, are pertinent to your controller as well. Check for burned, missing or otherwise "odd" looking components. Once everything is properly cleaned give it another try. Water damage is the hardest to repair since virtually any part can fail.
Punteggio 1
1 Commento:
So I cleaned out any corrosion I found on the boards and now it’s back to turning on only when plugged in. I replaced the pins that directly touch the battery as well as the battery itself.
da
Aggiungi la tua risposta
RobertAdams313 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 66
