Salta al contenuto principale
Repair guides and support for Panasonic's Viera line of televisions.
Tc-p50st50 flashes 6 error code
I have a 2012 Plasma that will go into a lockout with 6 error code flashes, I can reset it using the power button on the tv, it will sometimes work for a week following the reset before doing the same thing, the next time the reset may only before a matter of seconds. I have checked the boards for signs of failures with not obvious problems. The troubleshooting for 6 flashes states that the most probably fault is the sc board, with the next most probable being the “a” board. I am uncertain how to determine with certainty which board is causing the problem. I did check the boards for loose screw grounding connections, there are signs of arcing in a few locations. Any help on how to proceed is appreciated.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @kwm
Here's an image that shows how to troubleshoot a 6 blink error code to know whether it is the SC board or the A board that is the problem in your model TV.
(click on image)
Punteggio 1
1 Commento:
Thanks I will give that a try,
da
Aggiungi la tua risposta
KevinM sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 408
