Salta al contenuto principale
Annunciato nell'agosto 2017, il Galaxy Note8 è il successore del Galaxy Note7 ritirato dal mercato ed è stato commercializzato a partire da settembre 2017.
Note 8 Freezes and restarts
My Samsung Note 8, has started to Freeze and then restart and keeps doing that until it's battery runs flat, sometimes locks up so bad I can't force it off.
I did some troubleshooting from Wiping the cache partition and factory resetting the phone and seems to work for about 2 minutes before freezing and going back into the loop, I also tried reinstalling the software for the phone with Odin but seems that doesn't fix the issue.
Any help would be greatly appreciated!
Thanks in advanced.
Questa è una buona domanda?
Punteggio 2
5 Commenti
Hi @littletech
Does it do this with the charger connected?
da
Hey @jayeff
I've tried whilst charging the phone and its gone past the boot logo and started a fresh install (guessing from me factory resetting) then It went into the phone worked for about 3 minutes before freezing and restarting few times then works normally before freezing and repeating the loop before just shutting down.
Some extra info that might be helpful: I got the phone refurbished, seems its originally Korean based as the provider is LGU+.
da
@littletech
Just eliminating things :-)
Try starting in safe mode and check.
Don't know anything about flashing new rom to get away from a Korean base but a quick read online seems to indicate that the partitioning is different so maybe it's getting confused if there's some remnant data left somewhere idk.
da
@jayeff
I tried in safe mode but unfortunately seems to continue to crash.
So i need to find a way to wipe the whole phone and then try reinstalling it all again?
thanks for the help.
da
Was your problem resolved with a new battery? I've been having the same issues since the last couple of days...
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
I'd try a new battery, sounds like its struggling to power the phone. it may be refurbished but is it? Some sellers describe a good looking phone as refurbished to get a quick sale.
Punteggio 2
3 Commenti:
Before I go through replacing the battery, is there a way to test that battery is causing the issue? as it still has the issues whilst on charge, so I wouldn't of guessed it was the battery.
da
@littletech I can't guarantee it, but there are a lot of devices that only take power from the battery; plugging it in doesn't directly power the device, but rather goes toward charging the battery instead, so if the battery is misbehaving it will continue to do so whether it's plugged in or not.
The only way I can think of to test that is to disconnect the battery, then plug it in and see if it comes up. Might be worth a try to help confirm or deny the battery as the source of your problems.
Considering you can buy a replacement battery for anywhere from $10 to $25 USD, it would be worthwhile to replace it and confirm whether or not that's the problem.
da
Hi @dadibrokeit
Okay, Do you have recommended sites to look for a battery since I've heard there are a lot of fake batteries online and ifixit seems to not have them least not for AUS.
Thanks for the help. =)
da
Use odin to flash the software down load the combination file for that exact model and version that will fix your device if it's not a bad battery and or charger cable
Punteggio 0
6 Commenti:
Will flashing the firmware delete user data such as photos, videos and other personal files?
da
@kwak1983
Yes.
If you're going to do this backup the phone to the cloud or a computer before flashing the firmware.
Once it is done and tests OK restore the phone using the backup that you made earlier.
da
I can't access the phone (black screen), but need the data on it, so this could be a last resort option.
da
@kwak1983
If you flash it or factory restore it you will erase all your data so it cannot be retrieved.
da
I have atrouble use for galaxy note8
da
Mostra 1 altro commento
Aggiungi la tua risposta
Littletechy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 66
Tutti i Tempi: 826
